I just changed my modem and now my base won't connect via ethernet cable. My power light is green, but my internet light is amber. I'm not sure what to do at this point. I did a factory reset and light is still amber. What can I try now?
It's a system wide outage of some sort, but the number for Support listed on the website is (408)-638-3750. I don't know if it's accessible right now or not.
mep123 wrote:There seems to be a system wide outage. See numerous other threads and posts. So far, to the best of my knowledge, there's been no official information or updates coming from Netgear. I find that more disappointing than the outage itself.
Netgear has been posting on their Facebook page, but it appears to be rather ad-hoc. https://www.facebook.com/arlosmarthome/photos/a.1559240674288047.1073741828.1540756022803179/1976852...
Same issue. Have had the system up and running for just under a week now. Had an Authenticaton Services error this morning which has since resolved. Tried calling the support number and it was busy for multiple hours. Busy. Really?!
Netgear was having server issues but all should be back to normal now
Still not working here
All should be back to normal now
No, it's not back to normal.
Thanks to everyone for the responses. Mine still show as offline.
on computer, when you tried to log into your account, you got a message explaining server issues and estimated fix time. All back up about 20 min past this fix time estimate
I've had the Arlo system now for about 3 years. My experience has been that the system is quite stable for the most part, with only an occasional hiccup usually associated with a firmware or app update. I've never experienced an outage like this one.
server issue was fixed a few hours ago and mine is working ok
just rechecked mine and all is ok. Maybe still not ok for some countries/servers
Nope. still not fixed for a lot of people
