After last update, the recordings made by Arlo are not smooth, as they had been before.
Problem is resolved.
Physicist,
Can you give more detail surrounding the issue? What do you mean by not smooth? If you have multiple cameras, are you seeing the same behavior across all of them? Is the issue intermittent or does it always occur?
It might help for you to upload a screenshot of what you are describing so we can better understand the issue you are seeing.
