one of my Arlo wi-fi camera starts recording solid black video clips.
my model is vms3430. Firmware is 2.6.1
this camera has been working fine for the past 10 months, and just started record black video clips from time to time since few week ago.
Is this the problem with this camera or it can be something else?
any help is appreciated. thanks.
Try a battery pull reset
hi, Steve_t,
thank you for the advice. I just tried replacing the battery.
The solid back video issue seems happens from time to time, so I need to keep observiing it for few days to see if there is still solid black video clip comes out.
So, do you think it's the issue with the camera? Pulling battery reset will fix this issue?
thanks.
Is it solid black at night only? Do you get any pink/red video during the day?
hi, Steve_t,
so far, the solid black video clip only happens during the night. During the day it seems working just fine. I don't see pink or red clip.
And the solid black video clip issue happens from time to time inconsistently. So, it's like the issue comes out now, after a while it seems working fine again during the night.
The solid black video clip look like this below, the whole screen is black through the whole 10seconds it records.
Thanks.
Can you, when it's dark, go out and walk in front of the camera? Can you see the red IR LEDs turn on? When it's recording, can you illuminate the area very brightly? Maybe just shy of shining a flashlight directly into the camera
hi, @steve_t
lso shine a flashlight directly into the camera. at this moment, it seems recording with night vision fine. the solid black video clip occurs once a while. So.... I am not sure how to regenerate this issue then.
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
