Can't Connect To Base After replacing Batteries
I replaced the batteries in my cameras and have not been able to get my cameras to connect to the base ever since. It tells me my base is off-line but it’s not. Then it tells me the cameras cannot connect. A day later, I get an email from Arlo stating that my batteries are tired. I just put brand new batteries in the cameras. I do not understand what is going on, please help
Have you rebooted the base? What are the LEDs showing? What have you tried? What do you see?
But what are the base LEDs showing?
Try both the app (on WiFi and cell service) as well as a computer browser. Does any one work?
I'm trying to figure out if there's a difference when trying to access the system. If the cell service gets you the proper indications/displays but WiFi doesn't, that tends to imply something about your WiFi. Use of a computer browser is another way to check to see if it's something about the app or phone.
There's no app for the computer. You just use a browser pointed to https://arlo.netgear.com
But you still haven't tried the browser nor have you said that you've tried using the app when connected to WiFi as well as cell service (away from home). That's valuable information to know if one works but another doesn't.
First, I'm a user, not an employee.
If you read the documentation that came with your system as well as online here, you'll see that you can use either the app on a mobile device or a web browser on a computer. You say you have a computer so you likely have been using a browser on that for web surfing, email, whatever. Open that browser and type in:
and log in.
My system is working fine so it's not a specific issue that's widespread causing everyone to have problems. We're trying to figure out if it's an app display issue or if the browser login has the same issue. Until you try, we don't know the answer.
You can also try unplugging you modem, router and base and then plug them back in, in that exact order. Wait for each unit to fully boot (~2 minutes) before plugging the next one in.
If all else fails, open a case with support here:
Ok I tried logging in from a browser and it still won’t connect. When I get home from work I will try unplugging everything and see if that works.
