A cloud update has been deployed that should resolve this issue. Please let me know if you continue experiencing delayed content.
The video may be there but just not the little icons of same... they were having a server issue re the video icons going to the library
The video is not there. The alert comes in but it takes 2 to 3 hours for the video to show up.
I wasn't clear.. the video was RECORDED to the servers, the issue was the video icons were being delayed being sent out so you in effect could not access them ( far end issue )
But with the alert, you can always go LIVE VIEW
I am also experiencing the same issue. Maybe something with their last update is causing issues. Hopefully they will fix this sooner than later.
I am still having the delay issues. Several hours after the alert is sent before the video shows up. Very aggravating. Maybe if we keep commenting someone will get this issue solved. I wonder if others are having this problem?
I have escalated this topic to engineering for review. I will post an update when I have more information.
Thank you James. Whatever they did seems to have fixed it.
