Re: Arlo turns off by itself and reboots (VMB3010 or VMB3500) after firmware update
- 2
- Email to a Friend
- Email to a Friend
- Email to a Friend
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Base-Station-VMB3010-1-12-2-14-817-e5957a9...
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
Batteries died.
- Email to a Friend
I have two VMB3010r2 base stations and they are turning themselves off all the time since the 1.6.297 firmware update. I am so fed up with my Arlo system that I just want to pitch them in the trash and buy a RING system! I just put new batteries in several of the cameras and after the disfunctional firmware update they are all now drained. Come on Arlo, you used to be a great product but you are not now!
- Email to a Friend
I see it is actually the firmware update 1.12.2.14_817_e5957a9 on the base stations that is probably the rebooting problem. Add in the battery drain of the firmware update to the cameras and what a mess. Good thing I am not out of town relying on Arlo security.
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
Hello Community and Arlo Support,
I have five separate systems running with 2-5 cameras each, spread across three different routers and separate internet connections. The problem of the base going offline and rebooting appears in four of my systems and several of my clients systems. I have opened a ticket (#42046222) with support level 2 and explained the following information:
From my investigation this appears to be a problem with the latest base station firmware (ending in e5957a9) for the original rectangular base (VMB3010r2) and the newer round base (VMB3500r4). It has not been evident in the one Arlo Pro base station (VMB4000r3) I have in the mix with firmware ending in c289687.
The issue/bug can be triggered by live viewing one or two of the cameras in each affected system. Once the first camera viewing is stopped the base goes offline, sometimes with the "internet" LED on and other times with the "internet" LED off. Sometimes live viewing a second camera is required to trigger the issue. The base then appears offline on both the IOS app and the web browser interface. After approximately a 6 minute timeout, the base reboots and goes back online. Sometimes cameras take a while to reconnect to the rebooted base.
The above issue/bug is repeatable in my systems and has been happening for several days since the new base firmware was installed. If you do not live view the systems, they continue to provide motion sensing recording and notifications when armed.
Please find this bug and provide updated firmware ASAP, or provide a path to downgrade the base firmware until the bug is fixed, as my systems are unusable for live viewing in their current condition.
- Email to a Friend
Thank you CraigTCS. This is exactly what is happening to my two VMB3010r2 base stations. Can we go back to the original firmware from 2018 when my system actually worked!! Loved Arlo the, not so much now.
- Email to a Friend
During my contact with Arlo support, they said there was no way to downgrade the firmware.
I am hoping that someone from Arlo will read this and provide an option to downgrade the base firmware for those of us who want our systems to function while waiting for them fix the bug introduced in the latest firmware.
- Email to a Friend
Still waiting.
- Email to a Friend
- Email to a Friend
Live view appears to be working again now.
- Email to a Friend
One base is off and 5 cameras off and batteries died.
I need to restart. And buy new batteries.
- Email to a Friend
- Email to a Friend
- Email to a Friend
https://www.olightstore.uk/olight-rcr123a-lithium-ion-battery.html
On a camera that isn’t triggered so much (5 times a week say) with 15s recordings and best quality video I can get 5-6 months.
These seem to get good reviews;
Arlo Battery Arlo Rechargeable Batteries [750mAh 3.7V 8Pack] for Arlo Wireless Security Camera (VMC3030/VMK3200/VMS3230/3330/3430/3530) https://www.amazon.co.uk/dp/B0868H8TRB/ref=cm_sw_r_cp_api_i_pxtPFbXYAJ3KZ
- Email to a Friend
- Email to a Friend
New firmware 1.12.2.8.9_fc4b603 works well on my VMB3500R4 BASE STATION now.
I guess it was downgraded.
- Email to a Friend
As some users have reported here already, we have reverted back the firmware version and your Arlo Base Station should now be working properly.
To update your Base Station firmware manually:
- Launch the Arlo app or log in to my.arlo.com.
- Tap or click Settings > My Devices.
- Select your SmartHub or base station.
- Tap or click Device Info > Firmware > Update.
Warning: Do not turn off your SmartHub or base station while the firmware update is in progress. - Wait for the base station firmware update to complete.
The base station Power LED blinks green while the firmware is downloading and installing. After the firmware is installed, the base station reboots and the Power LED lights amber. When the Power and Internet LEDs light solid green, the firmware update is complete.
If you're still having some issues related to this (or your firmware is not getting downgraded), please let us know with a new thread.
- 2
