Arlo stuck
I'm having the same problem. It's an issue both on the IOS app and the web.
Yup, I dont use any app at all (WP user so...no app) but I've just been getting a "Getting Status..." message from the portal after logging in. I tried rebooting the device, my router, etc.
Weirdly enough, the cameras still seem to be running and recording on the schedule.
Over the weekend we experienced an outage that may have affected a small number of users. This was resolved a short time after the outage was discovered and we are investigating the root cause. Please let us know if you are still experiencing any issues.
Acyhuk,
What issue are you experiencing? What device are you having the issue on?
Also the desktop says it is offline yet the base has the three green bars
Should I return item?
What did you do that caused it to ask for a network security key? The cameras only connect to the base and the base connects to the router through a cable so there's no netowrk key needed.
What do we do. Our friend claims the system is on an working ! But we still can't view it !???
Try power cycling the base and your mobile device(s). Is this happening on both WiFi and cell service?
