  • 5 Replies
  • 2447 Views
Groothe
Hi
Is close to selling my arlo system 🤬 It has worked for several years but all of a sudden I only receive notifications on my phone when the screen is on. I get absolutely no notifications with the screen off. I have tried to reset both cameras and router but without luck. What should I do?
5 REPLIES 5
Have you turned off battery optimization for the app in the phone settings?
Groothe
yes I have
remove then re-install the app
Groothe
I have tried that but without luck, unfortunately. Have also tried a completely different phone with the same result
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
