  • 9 Replies
  • 4579 Views
  • 7 In Conversation
gillespie
I have a new Dell with windows 10 with google chrome.  It's been working just fine untl 2 days ago.  The live feed will not come on.  It keeps getting blocked.  My settings are set to Allow flash.  Why would this stop working all of a sudden?
9 REPLIES 9
manfredz
Hero
Hero
does it work with another browser?
steve_t
Master Master
I had to go into the Chrome Flash settings and specifically allow arlo.netgear.com
rodewalr
I experienced the same problem with my Chromebook.  It is clearly a browser problem.  Since the Chromebook uses a different version of the Chrome browser than the one used in Windows, the fix is slightly different.  For the Chromebook, type in chrome://flags.  Search for "flash" within the daunting list of options.  Switch the "allow flash" settings from default to enable.  Worked for me.
rodewalr
P.S.:  Chromebook fix.  Seems you also have to do a full Chrome OS reset after enabling flash.  This is easy to do using the chrome://flags settings.
marcNZ
Hi,
I had trouble getting live images on my ACER laptop running latest windows and Firefox and similar on iMac running latest OS and Firefox, both with latest Flashplayer. So I tried Safari on the iMac...and it worked first time with no hesitation or issues...
Also runs great on my iPhone...so not sure what the problem is for the other setup.
Hope this helps someone.
Did you enable Flash in the other browsers? As noted in many other threads, recent browser updates disable Flash by default - you have to enable it.
royaschroeder
I have the ARLO app installed on my MacBook. The live feed feature previously worked but now it says I need to update the Flash driver. I have updated Flash several times to no avail. I get the same result when using FireFox ot Safari. Is the Arlo app just broken?
The app doesn't use Flash. It's only required for browsers.
The latest browser updates turn Flash off, as reported in several threads here. You need to use the browser menu to enable Flash.
