My device display now shows each camera location twice. I have made no changes to my settings prior nor updated the app. All of a sudden I get two camera displays of my driveway, front door and rear decking. The only difference in the displays is one camera shows the wifi icon and the battery life icon like always - and the second camera does not show the wifi icon and the battery life icon is outlined in red. Same for all three cameras. I'm using version 2.3.0 for the iphone app
Additional info - I had disabled two cameras last night because of excessive activity in thoses areas. The "real" display shows the picture on those cameras shaded with the standard message "this camera is currently disabled ....". On the "ghost" cameras a picture shows from 14 hours ago with no indication the cameras are disabled. The wireless icon is missing and the battery is a red outline as described previously. Would seem to indicate a problem in refreshing the device status and/or image.
iPhone 6SE with ios 10.2 - deleted the app - reinstalled - everything restored properly. Problem did not occur on iPad Mini with ios 9.3.5 or Windows 10.0.14393.
For Netgear technical support: In trying to resolve the multiple camera display issue observed the following:
Logged into iphone app with Arlo login. Went to view from Windows with same login and it forced logoff from iphone, all camera status was lost, and internet connection light went amber. Attempted to re-create this condition and logoff was forced but impact to camera status and internet connection were inconsistent. Changed Windows login to a user granted "Shared Access" and it never occurred.
Please explain "Changed Windows login to a user granted "Shared Access" and it never occurred."?? Thanks!
You can grant other people access to one or more cameras with different access rights. I set one up for my wife and myself. I can use my "Arlo login" and sign on with the "granted right" simultaneously from multiple devices. The following link discusses this:
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-add-friends-to-my-Arlo-account/ta-p/40
Hope this helps - let me know if you need any additional info.
Deleting the app and reinstalling has been tried before by others. The problem reappears.
Personally I'm not of the mindset to have to reinstall the customized schedules and geofencing as well as the camera settings again, especially when Support has not indicated this to be a fix. It's strictly a software issue with the iPhone and Arlo software. iPad does not have this problem as far as I can see. Arlo is a premium product and it can be fixed. It just needs focus by Support.
This issue is still being investigated by the engineering team. Please do not attempt to remove the duplicate cameras as this does not resolve the issue. Some users have reported having success by uninstalling the Arlo mobile app and downloading a fresh version from the app store. I will post an update when I have more information.
We apologize for any inconvenience this may cause and thank you for your patience,
I am still waiting on a fix. Can Netgear just revert back to previous version until this version is fixed? It is very frustrating as I tried everything and no luck. Also with the double cameras I do not get notifications if the cameras is activated? Come on Netgear this is taking too long??
Device display showed each camera twice and also duplicated the base station, so I deleted the duplicate base station. Have since deleted app from my iPhone 6S and reintalled lated app 2.3.1. I am now unable to connect the base station althoug I have all 3 green lights showing. Unable to get throug to tech support eitrher! Very dissappointing Netgear!
Trich,
If would like to assist you with getting your base station back online, I will reach out to you in a private message for more information.
Surely this isn't hard to resolve?! It's been weeks now!!!
This issue has been resolved in iOS app version 2.3.2 please visit the app store and update your Arlo mobile app to this latest version.
2.3.2 fixed my problem just fine. No more ghost server/cameras.
Thanks Arlo Support team - good fix
My problem is resolved.
I have found the solution ! and it works. Ignore it"
The camera duplication is happening when i use Geofence.
When i stop using Geofence the duplications disappear.
Geofence works fine.
