Arlo camera does not power on
I was changing the batteries on my camera, the blue lights were blinking and I noticed the door wasnt fully closed. I opened the door while the lights were in process of blinking and closed it properly.
Now the camera will not show any signs of power.
I removed and replaced the batteries again, tried new batteries and tried to resync. Still nothing.
What else can I do? Thanks.
Remove camera in settings ( Remove Device )
pull and replace batteries... attemp to bring back as new with sync.
If NG ( hopefully it wasn't updating the sw ) contact Netgear Support
Thanks for the help. Much appreciated.
Did you have any luck I have the same problem
No luck. They ended up replacing the camera, " as a courtesy " because it was past one year warranty. 2 months later another camera continually went offline. After many emails back and forth problem is hardware failure.
For a camera to fail when it is soley used indoors after only 2 years of use is unacceptable. Arlo refused to make good.
Will never buy another product. Horrible service. Inferior products.
