Arlo camera does not power on
  • 4 Replies
  • 10211 Views
frankf55
I was changing the batteries on my camera, the blue lights were blinking and I noticed the door wasnt fully closed.  I opened the door while the lights were in process of blinking and closed it properly.
Now the camera will not show any signs of power.
I removed and replaced the batteries again, tried new batteries and tried to resync. Still nothing.
What else can I do?  Thanks.
Remove camera in settings ( Remove Device )
pull and replace batteries... attemp to bring back as new with sync.
If NG ( hopefully it wasn't updating the sw ) contact Netgear Support
frankf55
Thanks for the help. Much appreciated.
MMAN
Did you have any luck I have the same problem
frankf55
No luck. They ended up replacing the camera, " as a courtesy " because it was past one year warranty.  2 months later another camera continually went offline. After many emails back and forth problem is hardware failure.
For a camera to fail when it is soley used indoors after only 2 years of use is unacceptable. Arlo refused to make good.
Will never buy another product.  Horrible service. Inferior products.
