Just recently, within the last 2 weeks the base unit (in 2 separate locations) keeps going offline. Is there a system issue that is not being addressed??? This is really frustrating.
Happens on wifi and cellular with different providers.
Deleting app and reinstalling makes no improvement.
Logging out and back in makes no improvement.
Was also occurring when using iOS arlo App v3.1
I have had this problem also ever since their last update release on 4/20/2021.
It seems to be connected to this update as I had no problems before.
I get alerts and my system functions as it is supposed to as far as motion detection and camera capture.
However, when I open either my phone app or the internet app, I get the message that the system is offline.
I was trying to turn the system mode to off this afternoon and it gave me this error.
While the app was still open and saying it was off line, I got an alert as I pulled into our carport.
Hope they get this bug corrected soon.
With increasing frequency all 14 of my cameras are offline. Regardless of signal strength. I have a good internet connection because I can get anywhere else using a browser.
What is the problem? Arlo's servers?
Cameras will trigger an record, even though Devices page says they are all offline.
This means outbound is working, but inbound from Arlo is broken.
For the mobile app, using android based Samsung note 9.
However, recall that I am having the same issues when logged into my account online.
After a week nothing has changed.
Red sign problem "You are not connected to the internet".....but only for around 5 to 10 minutes at a time.
And like I said before.......It doesn't matter if I'm on CHROME, MICROSOFT EDGE on the computer.
Same here. After losing control of my cameras and base station and following the hour of work uninstalling, reinstalling, setting everything back up, it worked for about a minute and now, nothing. It wants me to do a factory reset on the base unit. I just did. If it comes back with now I have to pay a monthly fee, it will finalize my feelings about this company.
Just checked my camera's again & the Red Sign "You are not connected to the internet" came up as usual but this time behind the sign the camera's were steaming live.
What the hell is going on with ARLO?
It's a Joke.
As a successful business operator, here's a bit of free advice Arlo.
You need to stop spending money on advertising & employ some more capable Technicians and fix this problem ASAP.
It's been around a year & a half now. Not good.
And just another reminder as this function still doesn't work.
I can "ZOOM IN" on the mobile but haven't been able to ZOOM-IN on the computer for the last couple of weeks (make it a month now).
Hi All
I was wondering if anyone could shed a bit of light on the following issue:
- my base station shows in the app/on the web as being offline, but it's actually online; this, however, is periodic, for example: 10 min. online and then offline for a couple of minutes (Internet connection is fine);
- as a result of the above, cameras don't always record all motion; I can see some videos, which makes me think that some motion is picked up but not recorded as a result of the base station being offline;
- the base station is connected to the router via an ethernet cable. F/W: 1.12.2.18_950_446c68d; hardware: VMB3010r2
I noticed that as a result, batteries deplete quicker (past 4-5 months).
Is there a way of obtaining a log of when the base station is on-line/off-line? Can Support access this kind of information?
Thank you.
As I expected, after a couple hours of trying to "fix" this problem, it wanted me to do a factory reset on the base. I expected that it would back me into the pay schedule and my fears weren't in vain. After I got the online version of this running, I tried to do the same with the phone app and had to reset it all once again to start over and lost the online access. As a matter of fact, neither version works now.
I can honestly say that if you EVER needed to depend on a company for security, Arlo is the absolute worst. I have never dealt with such a miserable, worthless, POS, deal breaking company as this....EVER! After years fighting, I'm done. I wouldn't even resell this system to save someone else the hassles.
Arlo, you set the standard for being the absolute worst company I've ever dealt with. Good job!
Mine is exactly having the same issue. I even reset the base station and put all the cameras back on, I'm still having the same issue.
I am also having the same issue that the system is intermittently offline. By the time I notice, it will usually reconnect on its own within a few minutes, but who knows how long it has been offline before that.
I have noticed something similar... ( couple other threads similar )
Mostly on web access ( which I use the most , so that may be the reason ).
The cameras come up as offline but all leds on the base unit are green AND the cameras record during this 'so called offline'.
Logging out and then back in seems to fix the issue for now.
Have notified Arlo about the issue and they are working on it.
What are the base LEDs showing when offline? Power, Internet and Camera should all be green. Have you rebooted the router base, in that order?
All the LEDs are showing green lights and still says offline.
My base station has been going off line for the past 3 weeks. Have tried every option that is recommended, reset it, unplugged it, removed device and then added it again. Happening from my laptop and my iphone. Not sure what else to do.
Judging by all the other posts of devices going offline lately I guess there's a widespread issue with Arlo, which is frustrating and unfortunate. I went all in with Arlo at two locations with camera systems and doorbell. Constant issues. Cameras going offline and failing to connect. The doorbell is super slow to answer. By the time it connects the person who rang the doorbell has left.
