Just recently, within the last 2 weeks the base unit (in 2 separate locations) keeps going offline. Is there a system issue that is not being addressed??? This is really frustrating.
I started having this error condition occur on my Samsung Galaxy Tab S2 android tablet. The app has worked fine on it for years, but started exhibiting the "not connected" red banner this morning. I am able to connect just fine with my Samsung S9 mobile phone. I am running the latest version of the application software (v3.1_28345). Rebooting the Arlo base station had no effect. I have not run across this issue prior to this.
same 5 plus weeks
They say this has been fixed but clearly has not for all of their users. Guess I'll need to be looking for a better camera.
Yes, I am running v3.2_28350. One of the first things that I checked was that I was running the latest version of the application. I have even uninstalled and re-installed it,
Yes, I was forced to when the working legacy version was completely wiped out. I am trying to go thru Smart Things to my camera; interesting thing, my smart things gave the not connected to internet error as well but was fine when I rebooted phone. Wish Arlo app would follow suit.
There has to be something in the new app that does not like the latest win10 version nor the S7.
After a month of 100% no issues, the last 3 days have raised the red sign problem again "You are not connected to the internet".....but only for around 5 to 10 minutes at a time.
Mods.......It doesn't matter if I'm on CHROME, MICROSOFT EDGE or the APP on the mobile.
PS. Also at the same time when these signs were present, I couldn't sign into this site to report the problem.
Can "ZOOM IN" on the mobile but haven't been able to ZOOM-IN on the computer for the last couple of weeks. Forgot to mention that yesterday.
The red flag sign is still coming up, a couple of times everyday for the last week.
Also, the camera's today (only started today but it's happened before) are now not showing live footage but are frozen on the first frame once you've signed in.
It’s been about for at least 2 weeks.
The arlo site status site says there are no issues at all.
I stumbled on this in an attempt to get the app to work on my phone after months of issues with 'you ware not connected to the internet,, etc.:
https://www.maketecheasier.com/fix-obtaining-ip-address-error-android/
Reloaded app and it has worked perfectly since. Hope this helps.
I have the same problem. App constantly reports cameras and base station as being offline even though all lights are green on the base station and the cameras are detecting motion. Extremely frustrating.
Are you still experiencing this issue with your base station appearing offline? May I ask which troubleshooting steps you performed so far?
Issue appears to be random as subsequent logins will eventually show the base station status ok. 4 out of 5 times the login will fail
Issue also occurs at the same time on second base station in use as a siren extension.
The App features affected during the failure vary from no camera loading in the App, detection indicators not shown or are not populated along with “getting information” in mode and eventually going offline.
The iPhone has iOS 14.2 using arlo 3.2.
The iPad has iOS 14.5 using arlo 3.2.
Both base stations have been power cycled along with the modem.
The base station internet led blinks for a second or so when the login fails where it normally lasts several seconds when successful at updating the status.
Base stations are 4000r3 with 4 pro2 cameras latest updates.
Interesting is that the base appears to still operate correctly and can still live view cameras and records etc.
I was able to get the app to work properly by turning off my VPN. Apparently, that is why the app wasn't seeing the network.
I have the same issue. I am using an Android phone. I am on the latest app version. I have to close and re-open the app several times before it successfully connects to the base station. However, it will connect to the base station every time if using a browser through my Windows PC.
Very frustrating!
Same issue here, been going on , on and off now for about a month but VERY persistent the last 10 days - ALL cameras show as offline, but base station is online and cameras continue to record if something is there. Can't "arm or disarm" anything, because nothing is "online". I rely on these due to security issues and also like to turn them off when need be when I'm here and this is super upsetting. I'm not going to keep re-booting and uninstall and re-install and remove batteries etc.... I need an answer as to why this is happening.
Thank you all for the information. Does this issue occur on WIFI & Mobile data?
Recently our Arlo Pro 2 system has been showing "offline" when trying to view via Google Chrome or MS Edge on a PC but shows up online and viewable via the mobile app. Tried on two separate laptops, same result. Why is this happening and how do we resolve it?
