I have the wirelss base station and 5 cameras. One camera is recording normally and I can view the recording in the app, but the app is showing all 5 cameras offline. I have reset the modem and the base unit but nothing changes. All three green leds on the base are burnng steady. How do I get the app to work again?
Working now.
netgear fixed a connectivity issue last night that seems to have fixed the problem for many. try again
Should be fixed now.
I have cameras that randomly drop offline. Resetting the base station does not work. The only way to fix it is to get the camera, open the cover and let it sit for a few seconds, and replace the cover. It’s a real pain getting the ladder, getting the camera, etc...
Has anyone had this problem?
Thanks.
I've had my Arlo for about 2 years. As of yesterday, it says that Arlo is off line. I've tried everything, including doing a factory reset and I can't get the basestation to reset. Question is do I need a new basesatation?
I can not log onto arlo to view my camera recordings. Why. It just does nothing after I put all my info in. I have tried 3 times.
Yes My base station has been offline for 3 days. Cameras work intermittantly and record in an unpredictable manner. Tried everthing to get the base station back online but nothing worked. It is likely a problem at their end. It really would be nice for them to send out a notice so everyone does not waste time like I have for the last several days try to fix a problem that is likely not on my end.
they had some issues last night which they fixed and many who reported problems yesterday reported ok today. havent seen anything about new issues
It is doing exactly the same thing again now. I can not return my system, but maybe I will be able to sell it to someone else and buy sometihing dependable.
Cameras came back on and are recording but no longer sending notifications to my email. The settings have not changed.
I powered the base off and on and everything seems to be normal now. I installed my first camera November 2016 and then added 4 more. I have never had problems until yesterday. I need reliability.
I just want Netgear to take this seriously and ensure they put procedures in place to make sure this type of thing does not happen. They may consider this system "not critical", but if someone breaks into my home and the system is offline, I am not going to be happy. Obviously someone broke something and they had no idea there was an issue until the users complained. Not good.
I've had my system since March and never had a connectivity problem (I did have a night time vision problem with one camera) and now I've been having connectivity problems with two cameras for three weeks now. I get tired of dragging out a ladder to reset the darn things. I just checked my system and the same two cameras are currently off line (insert anger face here). If this is a Netgear issue, it sure would be nice to get some information on how to resolve the issue. I really don't want to call their customer support line to have someone read through a script on how to resolve my issue, especially when I've already gone through all of the trouble shooting.
Arlo is driving me crazy. We get is all loaded and synced...it works for several minutes and then it says " offline". We try to reboot the base station...but a message says "Authentication invalid." While all of this is happening...the cameras detect motion and send a message to my iPhone...but no video. So, it is "offline" but detects motion. How can I get this system working properly! Help! Help!
I am also having the same problem with one of my cameras out of the 5 that I have. None of them went off line before unless batteries went dead and I have had these for at least a year now. In the past two weeks one camera has gone off line three times and I too, have to get the darn ladder out, climb up on the roof and go through all the steps everyone else has gone through. It is becoming VERY ANNOYING !! At first I thought it was the batteries, so I replaced them and it worked for a couple of days and then it went off line again. So again I pull the ladder out, climb up on roof, open the compartment where batteries are, pull them out and put them back in. I got a slight blink of the blue light on the camera so then I thought well maybe there is a bad battery among the four fresh new batteries that I had just put in a few days prior. So I went ahead and replaced them again with four other new batteries and it worked! Now, less then a week later it's telling me it is off line AGAIN!! PLEASE, WHAT IS GOING ON WITH MY CAMERA AND EVERYONE ELSES!? After reading all the posts, apparently it's not just a problem I am having! WE NEED DEPENDABILITY!!! PLEASE FIX THE PROBLEM GUYS!!!
Hard to say for sure but it could be a signal strength/quality issue. Swap cameras around to see if it's the camera or location.
I'm having just the same problem on a system working fine since early 2016. Tech Support have even replaced two cameras but to no improvement.
I believe the problem is related to batteries (since firmware 11810) and a system "restart". On cameras with lower (but not flat) battery strength the camera will not connect to the base station without the dreaded battery cover lifting process. The other observation is that a camera which is in this offline state will flatten the batteries very very quickly as I assume it continually works to try and connect.
This is certainly a problem since a recent firmware release.
Work around is to avoid "restarts" but if necessary replace batteries on affected cameras (or just lift the battery cover for a few seconds to reset it).
All very frustrating that Netgear do not find these problems before pushing out new firmware 😞
Hoping this will get fixed soon!
I'm having the same issue I have 1 camera that is working fine and is online but the other camera says that its's offline and I've restarted but base unit several times and my router.
I'm not having issues with the same firmware version. Consider a system reset by removing all devices from Settings, My Devices. Use the Add Device button to add the base and sync the cameras. Verify firmware versions of all devices by comparing to what's posted in the Release Notes section here.
All of my cameras are staying online now but no longer record or send notfications. They are all set to record when motion is detected and send notification to my email. Netgear should not fix something that was working perfectly. I wonder if they will ever get it back to a reliable system.
you might want to check that your system is armed, and if you're using a custom mode that it's selected. and that notifications are still selected.
If thats ok, might want to recreate the mode and use it.
