So I have two cameras and one is fine and works normal but the other wouldn’t sync back to the base station. I changed the batteries and attempted to sync like normal (with the button on the base and the sync button) but now the camera only blinks blue when I close the battery cover and it’s a single slow blink after that it doesn’t light up when I try to sync. What am I supposed to do?
I also have removed the device in an attempt to reconnect it but since it doesn’t light up, my app can’t find the camera.
Open and close the battery door to reset the camera. Make sure you get a single blue flash when closing the door to indicate power is applied. Briefly press the base sync button (don't hold it for 2 seconds) and then the camera sync button. Any better?
Use the Contact Support link at the bottom here for a hardware problem.
