  • 8 Replies
  • 5890 Views
  • 4 Likes
Argutos
One of our arlo cameras will not reset the battery indicator when new fully charged rechargeable batteries are installed. Is there something else to do to make that happen? All the others reset to 98-100%. This on is stuck at 48% which it was when the old rechargeable batteries removed.
8 REPLIES 8
Try and power button reboot the base.... off then on and wait 2 mins to come fully online
check
Argutos
Will I lose all the other cameras and have to resync them? I had a lot of trouble setting them up in the first place.
Argutos
Tried the power reset and didn’t change the %. Went from 48% to now 46%. Could it be the camera?
brh
@Argutos
If you are using the original Wire Free HD cameras with 4 batteries, bear in mind that the batteries work in pairs, so they can work with two batteries and show half the charge. The usual fix for this is to drop the batteries in and let the pressure of the battery cover exert the right amount of pressure to properly seat the batteries. Also look for corroded terminals inside the battery compartment. You also could try a set of Lithium batteries to see if it is a battery type problem.
Brian
Argutos
Thanks Brian,
The rechargeable batteries are new right out of the box and charge up before installation.  I think of the first 4 batteries, two were bad as they didn’t light up the charger but the recent four I replaced with were all green. They are tenergy 3.7v.  The camera just won’t reset the battery monitor and started discharging from 48% which is where the original rechargeable batteries were when removed.  Could the bad batteries have damaged the camera or vice versa?
thx
brh
@Argutos
It appears that one of the banks of the batteries is not working for some reason. Do the contacts appear to be clean?
Argutos
Thx! I’ll ck but it’s a new camera so wouldn’t expect corrosion?
brh
@Argutos
If it is a new camera, then you definitely need to contact Customer Support to get it exchanged under warranty.
Brian
