  • 1 Reply
  • 1228 Views
StorckNest
I have an Arlo model VMS3330W and I want to get an outdoor charger for the cameras as they do not hold a charge with the batteries for long and it is annoying to have to keep recharging them and replace them.
This is one of the original Arlo camera sets. so it is not the Pro, Ultra or any of the new ones. I plan to use the magnetic plug in charger but am not sure if this will work with the original Arlo cameras.
Can someone tell me if this is possible and will work before I spend my time energy and money to get all this and find out it won't work.
Thank you!
Sandi
There is no outdoor charger for the original Arlo camera that takes 4-123 cells.
What you have to do is buy the tenergy  or compatible 123 rechargeable lithium ion‘s at 3.7 V and use them in the charger that is compatible for them.
see attached
https://www.arlo.com/en-us/products/arlo/tenergy_rechargeable_battery_charger.aspx
