Arlo VMS3330 Charging Station?
Which charging station and batteries should I buy for my Arlo Model lNo. VMS3330 kit?
It's recommended that you use the Arlo-certified Tenergy batteries as found here in the product accessories. A search on Amazon or Google for "Arlo Tenergy" gives many results.
And which charging station should I purchase? There are so many different ones on Amazon UK! I want to make sure I get the right one, thanks.
The Tenergy one is a good start. Best bet is to use the battery and charger package. I'm in the US so don't know what the UK Amazon site may show but here there are sets of batteries and a charger, all from Tenergy. If you don't see them, there may be other options that could be useful replacements.
