- 2
I have scheduling set up with 4 x wireles arlo camera connected. Two of the cameras are inside the house.
I thought it was strange for a while as nothing has been showing in my feed dueing the night - normally I pick up cats outside and inside my kids trigger it if they get up during the night.
I went past it during the night when I have it set to 'paranoid' mode which is basically all careams activated and triggered with 90% movement. But I doticed the iR lights didn't activate when I went past it.
I reviewed my app and the mode shows as 'Disarmed' even though it's set to sceduling and I confirm that time they should be active. It's not just incorrectly displaying the status as it also never records anything. I confirmed at the time that base station was up, internet etc was working.
This is getting really annoying as I paid good money for home security and it seems it's not working during the night which is when I'd like it most to work.
Base station is running the following versions:
Have you been using the app to check/set your schedule? The apps have issues displaying and setting modes correctly all the time. I recommend using a web browser to do this since it works properly and consistently.
See what support says:
It's possible your profile is somehow the problem. You could remove everything from Settings, My Devices and use a new account, using a second email address. Don't know why that would work, just that a few folks have had success.
I used a web browser to delete my schedule and then re-enter my schedule and it did not switch to "Disarmed". The web browser route works!
By using the web browser to delete and re-create your schedule, the problem is solved. The problem stems from creating the schedule on the app. You can still use the app after you recreated your schedule for your custom mode.
I'm still heavily impacted since a couple of months
Geofencing, with schedule set at night, the cameras just stays disarmed in the middle of the night, for that price!!
Hi @Viking42
I reported this to customer care in November and they couldn’t fix it so closed the reference in February then on the same call opened another... basically they don’t know what’s wrong with it. In the meantime I’m using batteries constantly cause of having to leave it permanently armed. It’s a mess.
@ShayneS wrote:
Hi @Viking42
I've been battling with this issue since I brought the system. I had a custom mode setup on a schedule to never be disarmed but it kept reverting to disarmed after a couple of days. The custom mode doesnt send push notifications when I'm around.
One support person I spoke with suggested that the start and end of any schedule cannot happen at the same time. They noted that I should try bumping the start to a minute past the previous end-time.
I've only just tried this but will post the results here after a week.
@Dmkohl wrote:
I am having the same issue. I discussed in a chat with support and they let me know similar to above you can not have a gap in “Armed” modes (so, you can’t have one end at 11:59 and another start at 12am - they must overlap a minute). This is impossible to do in the app, so they make you login on your computer to make the edits. I have not tried this - but they claim it’s the fix. I let them know how ridiculous it is to have to login on a computer for a system that claims to be able to be run from an app, but that’s obviously not the chat agents fault so didn’t go into too much detail. Very frustrating!
Actually what TS had told you was incorrect. You cannot set up schedules with overlapping end/start times. If you try their system will adjust your other schedule so it doesn't overlap.
What a piece of *, geofence function not working, and scedule not working. Geofence stoppes working 3 month ago and scedule stopes working (from the ios app) over 6 month ago. Netgear has released selvrealisering updates adding new PAYED Plans WITCH works ! Atleast the credit card input part. But the functions that does not work, they dont fix. Adding homekits, doorbells and all kind of crap but DONT fix the problems that persists ?
Can you provide a little more detail regarding the issues you are experiencing? What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
You may find this funny but I had the same issue. What I discovered is that it is not limited to more than two different modes in a day but limited to not using the same mode more than once in a day. I tried to activate all the outside cameras from Midnight to 9:00 AM. Then from 9:00 AM to 9:00 PM I wanted run all the outside cameras but to turn the cameras by the pool off during the day. Then from 9:00 PM until midnight I wanted all the outside cameras on again. The cameras would go into disabled mode during one of the times when all the outside cameras were suppose to be armed. I made an identical mode and called it Outside Only PM so it ran with 3 different modes during the day with 2 of the modes being identical with slightly different names. Obviously this is totally screwed up programming but it worked!
- 2
