My Arlo has all the sudden stopped working and has a message saying it’s not connected to the internet! My internet is connected and on my hub the lights are lite up saying it’s connected but the app still says it’s not! Can anyone help me with this please?
Months later and these are still garbage eh? I gave up and just left the dead cameras hanging off the house until this gets resolved. By that point I probably will have installed my vastly better POE 4mp hard wired cameras through the attic, and then I'll just sell these for whatever triffle I can get or move them indoors to places I can't run wire to through drywall. At any rate this product was mediocre until early summer when it became utterly useless because of the constant disconnects and battery failures.
Black screen at 4 am, what good are these cameras??
Just rebooted my hub as all 5 of my cameras were offline again. This is a freakin joke. Batteries appear to be dead on two cameras. They were fine yesterday. Don't buy an arlo, total crap.
Not only are my cameras going off line, but even the cameras online are no longer making recordings or sending alerts.
I think most of you have posted the only reasonable solution - buy another system. Sigh!
I had my four cameras for a couple of years. About a year ago one camera just went off line. I've tried everything reboot ...
Just gave up settled using three cameras. Then the other day two more just went off line. Nothing has changed now I'm down to one working camera... Why is this happening and Why isn't there a real solution here? Why would one still be working if it was my wifi?
For what it's worth. I had bought a 2 arlo set initially and was using that base. A year or so later the 5 camera system was on sale on amazon so I had a second base. I finally caved, removed my first base from the account and loaded my 2nd base instead. I re-paired my cameras to the 2nd base after replacing all of the batteries. Now everything is working again...but support was not really able to diagnose anything. They never indicated there was any issue with the first base unit. good luck.
Do you know the model #s of the two bases? I was contemplating getting a PRO base and see if it would end this nonsense, at least I'd get local recording as an added feature.
Ineffective system! How does Arlo get away with this kind of shabby customer service? If their product is as bad as it appears, why hasn't the Fair Trade Commission stepped in yet with a massive recall? Before it gets to that, Arlo just needs to get their act together and supply customers with a stronger service - one that doesn't require owners to constantly remove and replace and reset.
Less than 2 weeks and a cam that always seems to have full wifi connection now has dead batteries again...and only 3 incidents were recorded. This system is beyond help. I'm pretty sure I'm ending my subscription this year. No support, and just a forum full of people saying how dissatisfied they are.
amen....I bought the camera to monitor them from 2000 miles away...I can't just hop on a plane...then go out & climb up the ladder, disassemble the solar charging system etc. etc every week when they go offline!!! this is maddening. I used to recommend Arlo to others...can't do that anymore till they find a way to fix offline systems from afar.
Same problem here - 3 cameras going constantly offline:
Base Station: 1.12.2.4_2772
Camera firmware: 1.3.319
Camera/Model: H7
Does the camera appear offline on the web browser & Arlo App? Yes
What Phone/Device/Model/OS Version are you using? 9.1.0.328 Android and MS Win10
Have all 3 cameras on an AC/DC adaptor so no battery drain and always full power supply.
Not always on property to check/change things in this crap.
This is the most annoying system I ever used - ARLO/Netgear's support is not existing and not responding here!
If there is the attempt for a law suit I am in - this company needs to feel the pain of their customers.
@ ARLO Moderator ShayneS:
Instead of sharing a link to the useless ARLO support why are you not getting us an update what the actions taken at ARLO to fix the crap you guys sold us?
Which stage is ARLO in with the fix for this totally unacceptable issues?
THAT and NOTHING ELSE is what we (the countless customers left alone with issues of your crap) want to hear from you ShayneS in this forum to avoid us return/discard this ARLO crap and change to another brand!!!
Well, here we are at 2019-09-29 and I (personally) am still not getting alerts when cameras go offline. If a person doesn't know their camera is offline, then that makes a VERY LARGE SECURITY ISSUE. Suppose an intruder sneaks up behind said person's camera and SHOOTS it. That would DEFINITELY take THAT camera offline, wouldn't it. You'd think that said person would want to know about that immediately, wouldn't ya... Most security systems DO alert if the cameras go offline immediately. Is Arlo for real or just like some sort of HI-TECH TOY?
This pass Sunday i charged my four camera's. I have one still offline. Did the box reset, pushed the button on top of the camera, just flashes blue. Any Thoughts?
