My Arlo has all the sudden stopped working and has a message saying it’s not connected to the internet! My internet is connected and on my hub the lights are lite up saying it’s connected but the app still says it’s not! Can anyone help me with this please?
Same problem.
Once again my arlo system is offline over the weekend. Just got the cameras back up, several of the cameras now have dead batteries. All my cameras were disarmed and I had to go back and make a custom schedule, it was gone. So tired of this junk, I'll never buy another netgear product. Total junk!
It's junk. Time to bite the bullet and replace it. Sick and tired of having the base station go offline, having to get a ladder to re-sync cameras, and having battery drain on random cameras for no reason.
What's the solution? I might just have to return it to Costco.
Hi @rsguy
Have you tried contacting customer service regarding this camera? I have attached the link here for you. Arlo Tech Support
Thank you! I'll try that tonight.
I've had them for little over 2 years . The issues with these cameras are so bad across the board I have often wondered how there hasnt been a lawsuit. The motion sensor lags so bad it rarely catches anything of value , they go offline for no reason , especially when I'm away.
The lag with the motion detection recording alone is enough for immediate action yet it's been over 2 years and they cannot or will not fix them. I have to use a 2nd arlo camera as a motion sensor to trigger the 1st to record , and even then the motion has to be just perfect angle and speed of motion to detect it.
The latest is I have a video at 2 am of my yard, where a man walked across and scaled my fence. No video of anything except where he had been. Useless. The only reason I knew I had a trespasser is because I installed a wired, 24/7 system. At the very least Arlo should not be selling new versions and products while never even attempting to make things right with customers .
I wish I could but I’ve had this system for at least 3 years and have just had the battery failure in the past 6 months. I did buy the Arlo recommended rechargeable batteries before Labor Day and have been monitoring their life very closely. Since I installed them I’ve only dropped 10%. This is the longest they have run since the firmware update from hell that started this problem. But I also added them all to a Schedule, recording at night only. TBD.
@TheWatcher24 wrote:
If you are still able to return them I would do so.
It did'nt help with the going offline issue, but I solved the freq. battery recharge issue by purchasing AC adaptors for my cameras
I eliminated the freq. battery recharging issue for my first generation Arlo cameras by purchasing AC adaptors for all my cameras. They cost approx. $30.00 each and come with a ribbon cable that can be passed through a closed window by closing the window on the flat ribbon cable
I purchased AC adaptors for my first generation Arlo cameras from Amazon. The cost approx.$30.00 each and now I don't have the frustration of freq. recharging batteries.
No offense, but the main selling point of Arlo is the wireless/battery capabilities. If you had power near your cameras I don't know why you'd chose Arlo. Also it doesn't Solve the issue, it just deflects it. Arlo team needs to fix the many bugs including this one.
