My Arlo has all the sudden stopped working and has a message saying it’s not connected to the internet! My internet is connected and on my hub the lights are lite up saying it’s connected but the app still says it’s not! Can anyone help me with this please?
I guess it could be the Mississippi heat!
Hi @RoniV
How far away are these cameras from the base station? is there a possibility the base is too close to the router? Have you tried to move it a little further from the router.
Hi @Finisher72
When inserting the battery for the Pro/Pro 2 & opening/closing the battery door for the original wire free cam, does the LED blink blue. This means the cam is powered on.
If you feel more comfortable contacting customer support now, I have attached the link below for you.
My cameras (6) had been working just fine for about 5 months. A couple of weeks ago they started going "offline". Changed batteries - no help. A couple of cameras came back, but others went offline. When I opened the battery door, paused, then closed it, the blue light started flashing and continued flashing till I removed the batteries again. Base unit has three green lights. At this time two cameras are working (of six). This is a bad system and can't be relied on for security. At this point I feel I've been ripped off.
Is anyone at Arlo or Netgear looking into this? It seems to be a fairly common occurance, with many others also complaining.
Hi @40974435
Have you tried to remove & re-insert the battery in to the cameras (Por, Pro2, Ultra), Open & close the battery door for (original wire free). Does the LED blink blue?
Hi @Kheard1
When you open and close the battery door or remove/insert the camera (Pro, Pro2, Ultra) does the blue LED blink?
When speaking with my internet provider's tech support about the problem he set up my router to use the opposite "channel", not a port, to see if this would help. Thus far my system has been online almost 9 hours with no hiccups!!
I will come back to this forum within the next 48 hours with a full report on whether this worked. In reality, if it does, it is a very simple fix!
After working just fine for a couple years, the camera now goes offline often. Others having same problem. I'm about ready to replace with another brand.
Hello,
I have a few questions for you all, this will help isolate the issue(s) you are experiencing
-What firmware is your base station running?
-What firmware are your cameras running?
-Which Camera/Model are you experiencing the issue with?
-Does the camera appear offline on the web browser & Arlo App?
-What Phone/Device/Model/OS Version are you using?
Hi,
My firmware of the basestation (WMB3010r2) is 1.12.2.4_2772. I cannot tell what the firmware was when I experienced the problem with drained batteries, but the cameras used 1.3.319 when the problem was there. Now the battery consumption is back to normal (since after July 3).
Hello everyone,
Which model cameras are you all experience the offline issue with?
Version 2.7.2
HW Version H7 -- Firmware 1.3.319
Wirefree - (Battery operation only)
Appears off line using Firefox and Win-10 Also with Win-7
-What Device/Model/OS are you using?
Using Windows-10
Message 26 of 27
And whatever 4 little cameras attached to it.
