I have created various modes and have them scheduled. If I look on the web site they all appear to set properly, on my IOS app version 2.5.1 it shows disarmed. My wife's IOS device running app version 2.4.5 shows the correct setting. I've tried recreating the modes and the schedule with no luck, I have deleted and reloaded the app on my phone (still version 2.5.1) with no luck and I've reset the base station again with no luck.
Any help would be appreciated
+1
In my case, using the same version of the iOS app (2.5.1 released 18th of May) the schedule I have set months ago seems to have changed (a time window in of one day of the week, Monday, shows to be absent (I mean: it doesn't show up ), while in reality it then is activated, which is good).
However, the planning situation as showed in the browser is correct, which means there is a difference in activated time windows in browser and iOS app.
A guess is this bug has been introduced in the latest release update.
Just downloaded vesion 2.5.2 and the error still occurs
It's been pretty quiet, I'm guessing most arlos are in working condition? Mine isn't! Since the update, it's been extremely unreliable. I thought it was working but once again it didn't record me coming and going. I checked my app and for some reason my rules that have been in place and saved were deleted. It recorded me earlier today but a few hours later, no recordings, no alerts, that's when my rules magically disappeared. I've already started all over as if it were brand new a few times already. No troubleshooting suggestions have worked. I've done all I can on my end and more. What gives?
Please go back to 2.4.9 which was working fine! Three releases and still no fix, cannot believe this!!
The engineering team has field trial firmware available that may help address the issues being reported in this discussion. If you would like to participate in this field trial, please post a confirmation in this thread and we will escalate your information to the engineering team.
Hi James....I would like to particpate in the field trial...thanks Alan
Hello @apd1212
I have added you to the field trial FW list. You should hear from the engineering team with further instructions within the next couple of days. We appreciate you taking the time!
Dawn Marshall
Arlo Community Manager
As long as is understood that my only problem (I hope...) is that schedules set by me show to be different in desktop browser and app, I am willing to sign up for experimental firmware.
Cortjan
@JamesC add me in too if its not too late. Thanks!
New Base station firmware has been released that should help resolve the issue being discussed here. Check your base station firmware to be sure you are up to date with the latest available version.
Take a look here for more information on this firmware: Firmware Release Scheduled 6/21 to Address IR Rapid Battery Drain and Modes and Schedules Issues
Well they messed up again! I'm offline. This is ridiculous!
it was working smooth on my iPad Pro when it was running on iOS 10 however as I have updated to ios 11.3 whenever now I am opening the app it only loads a blank screen on the start up and crashes after a while automatically. How do I fix it?
Hey @Jmj93,
What iPhone are you using that shows your camera is showing disarmed but should be armed? Make sure you are on iOS 12.1, which is the latest version for iOS, and the latest app version, which is version 2.6.1.
Was this issue fixed as mine has just started since the latest update
Hey @DeanRichards,
What iPhone are you using? And are you experiencing this issue through the web version? Make sure you are running your iPhone on the latest iOS version.
of course i am using the latest IOS version and the latest iPhone ARLO app. I am using an iPhone XS Max and found a fix to this issue on the weekend.
It is another bug in your iPhone App.
What I did to fix it was to go to: Mode: Geofencing Edit (pencil icon): Changed the Radius from small to large: selected DONE: Saved: Geofencing Edit (pencil icon): Changed the Radius back from large to small: Selected DONE: Saved.
After doing this, it now functions properly. (until the next bug is found)
Or Apple fixes their issues.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy924
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,067
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
