Arlo Camera counters not working
My Arlo camera counters have not worked for several weeks. Is there something I need to do to reset them? It sounds like Arlo is aware of this problem. Are they considering deleting this feature because it's causing problems with system? A little feedback would be greatly appreciated.
JamesC wrote:Also you will see your counter reset to zero when you visit the library, or you click on the counter on any of the cameras to go into library.
Hm, interesting.
At first, I was inclined to question that, as it seems to depart from the previous behavior. Before, didn't the counter always show the number of available videos to you that were retained in the library according to your subscription plan?
But, ok, resetting the counter when going into the library makes sense in a way, too. I'm sure we'll get used to it in time.
Schorschi wrote:
JamesC wrote:Also you will see your counter reset to zero when you visit the library, or you click on the counter on any of the cameras to go into library.Hm, interesting.
To me, that doesn't make a lick of sense. The counter should show the current count of events, for the current day!!! As a user/subscriber and this being a security system as marketed by netgear, it is up to each individual to do their own housekeeping, check your events and delete evrthing that doesn't matter. History, is history, I want current information for the current day!!! I can go into the library for history!!!
Gud Lawd!!!The counter should never clear, just because you go into the library, that's just ignorant!!! It should only start over when you've deleted the recordings for the current day!!!
I may want to know why traffic has all of a sudden increased in my neighborhood and I want the counter to count events, because that's what a counter is for!!!
If this is to be a first rate system and counters being fairly basic logic, there should be a counter for each day, or at least a seperate counter for the entire library.
After you log in, the first thing you see is the cameras, so that counter should show the total events for the day so far!!! It should never be reset, just because you reviewed a clip in the library, never!!!
