  • 6 Replies
  • 4434 Views
  • 5 Likes
newyorkgroove
I've had this problem for quite some time now and I don't recall that it was a problem prior to some recent Android system updates.
I have the Arlo notifications turned off in the settings of my Arlo app, however, it continues to send me notifications. I have tried uninstalling and reinstalling the app followed by turning off the chime again in settings, to no avail. How to I turn off the chime notifications in the Arlo app? I suspect this is a software bug created with recent Android updates?
Nighthawk11
I had the same issues. I went to settings, then app notifications, find the Arlo app and turn off notifications. Then open the app, select settings, then notifications. If it helps any, I found an older version of the app on APK Mirror, version 2.5.3_22376, which is working great with Android 8.1
6 REPLIES 6
Nighthawk11
ShayneS
What version of the Arlo Mobile App are you running?
Nighthawk11
Using 2.5.3_22376
You're way behind - the latest is 2.6.5.
Nighthawk11
That's because it doesn't work well with Android 8.1. I tried everything on these forums to get it to work properly, and no joy. Either way, I have to use an older version to get it to work correctly.
newyorkgroove
I rolled back and that fixed it for me as well.
