Cant Disarm Arlo
Talked about this crappy system on the radio this morning and you wouldn't believe the number of calls I got from people experiencing the same thing...before you ever think about buying this system RESEARCH all the little issues you'll have with it beforehand disarming is a major issue. Read these boards. There is an open market for someone to develop something like this that actually works consistently. One problem solved 2 more pop up. I cant recommend buying this...its ridiculous how many issues I have had with a 700 or 800 dollar product with the add ons...UGH!
KimCarson,
Can you provide more feedback on what you are experiencing? We may be able to assist here on the community.
