Why am I having so much trouble setting up the Base station. I note that its number is not being displayed. I have re-set the unit and set up cameras numorous time still no luck.
HELP Maybe the best is to return it. Can't use it any way. Does not perform as advertized.
Hi LexJDias,
We apologize for the inconveniece you are expriencing.
Installing the Arlo needs the base station and the computer or mobile phone/tablet you are using be in the same LAN. You need a router where the base station should be connected via LAN cable. If that is a wireless router, mobile phone/tablet you use should be connected to the SSID/wireless network name of the router.
Checking the LEDs is also important.
Please visit these links below:
Please let us know if you still get any trouble setting it up.
Regards,
NETGEAR Community Team
Bubba1023,
Welcome to the community! What is the behavior of the internet LED on your base station (Dark, Amber, Green)? If it is dark that tells us it is not communicating at all with your router. This could indicate a bad ethernet cable, a bad router port, or a bad base station port or defective LED. If it is amber that means the base station is connecting to the router but is not detecting an internet connection. If it is green that means it is connected to the router and is picking up an internet connection. In this case consider a two button factory reset of the base station and attempt to go through the new system setup.
Let us know!
Bubba1023,
You can log in from your phone by using the e-mail address you used on your wife's phone to set up the system. The account is not permanently bound to the device used for setup. Alternatively you can share cameras and send a friend invitation from the primary e-mail address to your e-mail address and create a friend account. If that sounds like a solution, take a look at the following article on friend account setup: How do I add friends to my Arlo account?
