iPhone 11 Pro Max, IOS 14.6
No idea what version of Arlo app because it won't even open up!! Get the screen with ARLO and the symbol, nothing else. I deleted the app and reinstalled so ASSuming it is the most current version. Also restarted my phone, and reset the Network Setting.
All I did was get a new router! My son has the iPhone 11 Pro and has no trouble.
Please help!
5 REPLIES 5
Hi VernaGarrett,
Are you having problems with the Arlo app when you're on WiFi and/or cellular data?
We recently released a new Arlo iOS app version, which is version 3.2.2. Try updating the app to see if that helps.
Unfortunately I can’t even open the app. I deleted the app and downloaded the new version but it still will not open.
Since it seems to be a phone-specific issue and you've done what I would suggest, I think the next step is to reset your phone.
