App freezes iPhone 12 every time I use the app
- 2
Every time I use the Arlo application it freezes my iPhone. I must wait 30 seconds or more before the phone stats responding again. In that time the phone will not respond at all. This is the only application that has this issue on my phone. iPhone 12 MAX. All of my cameras are updated and my phone is updated.
I have an H4 and H3 cameras also. 4 cameras total. 1 is WiFi at a different location.
I have reinstalled the application.
I see in the community that others are having the same issue.
Please help.
Which version of the Arlo mobile app are you using? There has been a few updates over the last couple weeks.
@omt66
@maricj2000
Which version of the Arlo mobile app are you using and iOS version?
It’s always the latest version, now and forever.
I can assure you I'm not a bot, This issue is not widespread. The questions you receive are required to help TS the root cause.
I do not experience this issue on an iPhone 13 Pro Max with iOS 15.5 & iOS 16 (Beta) with Arlo Secure app v3.6.8
@maricj2000
I have sent you a PM. Please let me know if you received it.
Thank you
iPhone 12 Pro Max running iOS 15.5 and Arlo version 3.6.8 (3421)
As soon as I enter live mode my phone turns into a brick. At this point my phone is frozen on the arlo screen and no combination of phone buttons will help. After approx 1 minute the phone hard reboots. Viewing recorded video works fine.
But I tend to agree, this is a bot support channel. I still never received resolution on accessing my data remotely again. It used to work. Then they changed the rules to port forwarding only. I can’t do that with Starlink internet.
So I had the option, one major reason I bought the second set of Arlo cameras with base station. It worked ; Arlo updated the code and poof.
Opened up a case here and was told “ working on it”. Was told “we updated (didn’t say if it was the firmware or the app). Still not working but nothing more from Arlo.
Was going to purchase another set for a third home, but I don’t think so.
I was contacted by arlo support. Ended up on a phone call. arlo app works fine from my iPad or web site. Deleted iPhone arlo app, rebooted phone, did a phone Reset Network Settings, re-installed arlo app. So far, working as advertised.
I am having the same problem. 12 max pro is updated, and so is the Arlo app. When watching the live video my phone freezes and when I try to shut it down it takes 1-5 minutes before it responds. I was hoping that I would find answers here but from what I have read, it doesn't appear Arlo has any solutions.
@MagicSkagit
Which version of the Arlo app are you using? I have reported this to my team in the meantime.
- 2
