Hello,
my antivirus Avast detected Arlo app on Android as a malware.
this is a false positive or I've to uninstall this app?
Thank you so much
m4xx
no matter which antivirus/antimalware software you use, you're going to get false readings. Assume you got the correct download from the play store
