Brand new arlo continues to say it's offline
Hi guys, I just bought a new Arlo set that I was really excited about. Everything seem straightforward and I installed batteries and synched both cameras and mounted. Problem is that one of them works quite well while the other one continuingly says it's off-line. I have tried removing the batteries and replacing the batteries and re-syncing numerous times but it never works more than a couple seconds before saying off-line. It is very close to the Wi-Fi source so I don't know what the problem is. Any suggestions would be helpful.
just a stab in the dark here. Take batteries from working cam and try in bad cam to rule out bad batteries as cause
Thanks. I've replaced the batteries with a brand new separate set and still having the same issue. Power doesn't seem to be the problem.
Swap at the store or open a case with support using the Contact Support link at the bottom here.
