Android app not working correctly Samsung
Yes, it appears at times the mode change does not occur
Same here. Since about November my arol app has not been working correctly. At one time I was getting 2 notifications back to back. Now after all the updates, I get no notifications. When I open the app it crashes. Always opens the second time I open it. When I select mode to disarm or arm it doesn't do anything. I have to then select a different option then after that option loads go back and select mode, which will then give me the option to arm or disarm. Also geofencing option had been removed. I am using a samsung s9 plus. My wife is using a iphone 7 and has no problems. I had no problems using the samsung until around November with the updates. I have tried clearing the cache, removing and reinstalling the app. Always comes back up with the same problems. Any ideas to help fix the problem?
