  • 9 Replies
  • 3086 Views
CR41G
On the latest version of the Android app, I cannot tap any of the three modes and edit their behavior when on the Routines page. I've tried this on my Google Pixel 8a and a BlueStacks instance. This is on the most up-to-date Android version. This is preventing me from making a lot of battery-saving changes to my camera.
9 REPLIES 9
It's working here. I just tried changing a rule in my Standby mode and had no issues. I've also been working on my geofencing setup and had no problems.
I'd suggest rebooting the phone and reinstalling the  app.
BrookeN
@CR41G Are you still seeing this same behavior?
CR41G
Yes. It's not a device issue. This is happening with my Pixel 8a, as well as a Samsung Galaxy S21 Ultra.
BrookeN
Did you do the steps above that jguerdat suggested? I would suggest those steps as well.
CR41G
Yes, I've rebooted the phones and restarted the app. Doesn't change anything,
BrookeN
Can you try to reboot the phone as well as reinstall the app.
To be clear, you're using the credentials for the primary user and not one that was granted access, right?
Justaname12
I am having this exact problem. I have tried every single troubleshooting option arlo offers. I need to talk to an agent, but you all have decided that you're going to charge for that now. Which makes me want to find a product that is 1. Easy to operate and 2. Is will to provide support when it doesn't. I just want to edit and/or delete routines. Why did you have to get rid of the calendar method? It was SO easy to operate and edit.
BrookeN
The calendar icon is still available. Under feed it is on the top right.
