  • 1680 Views
maunderstc
The amber light on my camera is steady on. Battery is charged. Still records but annoying having light on
Try pulling battery and replace to reset camera...
If NG, reset the base via the power button ( off-on )
maunderstc
I exchanged batteries with other camera. Same camera has steady amber light. Reset base with no change
Remove the camera from Settings, MY Devices and resync. If that doesn't help, contact support using the link at the bottom here for a hardware issue.
