All cameras stopped recording suddenly
cameras started recorded every 10 seconds yesterday afternoon which was very strange then they suddenly stooped picking up any motion./recording. I have tried turning off the base station. The cameras are streaming live but not picking up any motion.. How can I get them to start recording again?
Go to your two default MODES ; all on / all off.
Turn on ALL ON, go to the live view screen and look at the top of the camera. The 'running men' sould ALL BE GREEN.
If they are not, then your mode has been changed.
Go to settings/modes and click on modes. click on the ALL ON then hit edit ( pencil )
Make sure each camera line at end is check marked GREEN ( means on ), if any are black click the check mark, then SAVE on exit.
Test live view screen again after tuning on mode ALL ON, they should show green running men to show motion is active.
BTW; If they are streaming live, they can not go into record mode as live overides the motion settings. It will auto return to motion if previous set on
That seemed to do the trick! They are all recording motion now. Thank you so much for your help 🙂
