corbeille
Bonjour
j'ai vu que la corbeille se remplissait au fur et à mesure que je supprime les fichiers, faut il la vider si oui comment?
merci
The recycle bin will 'auto-delete' after 7 days.... ( at least it's supposed to be 7 days but sometimes they will stay there quite a while before deleted. But, they don't count towards you max storage space )
