  • 7 Replies
  • 4630 Views
JimSwindell
I purchased a Arlo Security System - 3 Wire Free HD Cameras (VMS3330) and all cameras go offline periodically.  The batteries are full, the base station has been reset and the wireless router is fine.  I receive no notification that are offline and the only way I can fix is take the cameras down and open the battery case to reset them. Why does this keep happening?
7 REPLIES 7
When offline, what do the base LEDs show?
JimSwindell
I am not currently at home but I will respond as soon as I get there.  Thanks
JimSwindell
The power button (left) is illuminated and the next button to the right are illuminated
But what color?  Amber indicates a problem, green means go.
JimSwindell
Green
Jrullo
Hi, this is happening with me too.  Just started a few days ago. Two out of 3 of my cameras are going offline, usually right after motion is detected.  All batteries are new and the system configuration/distance from the base station hasn't changed in over a year.
Lack of a green Camera LED means no cameras are connected. This can be due to dead batteries or something that caused a lack of sync, such as an extended power outage. You'll need to resyn the cameras.
As for occasional cameraoffline messages, I've been getting some of those recently, too. I find that logging out and back in fixes it.
