All Cameras Appear Offline
  • 9 Replies
  • 3961 Views
  • 5 In Conversation
willpete
All devices offline
First cameras were offline.  have used system several years.  Removed cameras then removed base station.  Re adde base.  No firmware listed.  camera devices (4) wont add.  green power,  green internet,  amber camera.   camera led turns green when sync on base pushed.  camera blinks blue.   stops and starts a few times camera led turns to amber.   no changes to my system.  Tried android and pc windows 10.
lost
thanks
9 REPLIES 9
Amber Camera LED means the base needs to be claimed. Remove all devices from Settings, My Devices. For good measure, press the reset button on the base until the LEDs flash amber. After booting, use the Add Device button on the Devices tab to claim the base. The Camera LED should then be out and you should be able to sync the cameras.
Make sure you are only doing a quick press on the base sync button and then the camera... some docs say hold for 2 sec which is incorrect.
willpete
thanks   TomMac
  for the repply.  tried it but was still unsuccessful
will
willpete
Thanks         jguerdat
Partial fix...                         Base and 3 of 4 camera  were added and are working.   all firmware is latest version.
Continuing problems:
1) one camera will not add after following same procedure with both android and pc.  several attempts each.  This camera was online and working properly prior to this fiasco.
2) 1 of the 3 cameras added goes offline after a base station is turned off and on with button.  times 3.   Adds back on no problem.
system is 5 years old.  Mostly flawless operation.  Initial purchase 2 cameras.  camera added at about 1 yyean and 2 years.
Will
It tends to sound like your base may be headed south. Do you happen to have another to try? Amazon has them for under $70 but you might want to try temporarily syncing the cameras to another base (maybe a friend's?) to prove they're ok.
You could also open a case with support here since they have access to logs which may be useful.
willpete
Thanks I will look into a new base
ShayneS
Hi Willpete,
To add to what jguerdat mentioned, You may need to escalate this issue to Arlo Technical Support. I have provided the link for Arlo Tech Support. Arlo Tech Support
dugchia
My cameras appear offline
ShayneS
dugchia,
Have you tried to reboot your base station?
