  • 2 Replies
  • 2173 Views
Josh-H
Hi, I need some help please - I  have a two story house and currenly have a ARLO base sation and 4 Arlo Cameras. My base station is upstairs and all the cameras connect to it ok, but the front door camera is a long way away and the signal is weak. I want to extend the range of my base station so it works better.
My base station is plugged into my NEtgear Orbi Mesh Router upstairs and I have a 2nd Netgear Orbi satellite right near my front door camera. If I purchase an additional base station and plug it into the Orbi Satellite will it extend the range of my Arlo system?
Streak2
Master Master
Yes it will. That's how I do it also using Orbi. You will then sync cameras to the nearest base.
You could also just try and move the Orbi satellite to a more central location and then plug your current base into it.
Josh-H
Thank you.
