Adding more wireless cameras.
Hi! I have two wired Arlo cameras and the base station. We also purchased 4 wireless. We used all 6 cameras over the summer and then we stopped using the wireless, leaving only the wired active. I have been trying to get the wire free ones going again and I can't get them to show up in "My Devices". They are functioning, as I was able to sync them with the base station yet no matter what I did I can't them to show in devices. I've tried even turning the base station off and restarting....help? Thank you so much!
Lynz,
When you stopped using the Wire-free cameras, was the base station removed from the account? If so, the base station would need to be added back to the account before syncing the cameras.
Ooooo DUH! That must be it, because I don't see the base in My Devices!!! So, the next $10,000 question is....how do I add it back?? I've already disconnected it from the router as well as turned it off/on.....thank you SO MUCH!
Thank you so much for your help, after I read your post I started to realize that something must be wrong because I don't see the base in My Devices, and the second solution from JamesC confirmed that I must have done something wrong. Thanks again!
Lynz,
You can add the base station back to your account by logging in to the account and clicking "Add Device". Choose "Base Station" and follow the on-screen prompts.
