  • 1 Reply
  • 1103 Views
Aubiedrake
I have 9 cameras that are the original Arlo and the Arlo Pro.  Some are not working anymore. Can I buy another system and add it to my existing cameras? As in having a set of the newer system Like the Arlo Pro 3 and still have the old ones working at the same time?
You can.   Though you probably should review the current subscriptions as you plan your upgrade.  https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
