Add Back Deleted Cameras
  • 8 Replies
  • 23103 Views
Burnn1
Both of my cameras were deleted and factory reset performed.
Base is connected to internet, and both cameras re-sync - but the don't show up
Camera screen only shows instructions on how to sync and no camera shots.
How do I get them back?
thedogmonster
I just noticed your excellent moniker. As we both have 1 post I'm trying to ascertain why you are considered an Initial Contributor as compared to my Newcomer labeling? Labels? 2015 Arlo. Labels hurt. Exception: self applied labels such as Burnn1. Haha! Stay cool. I hope you get your system squared away.
8 REPLIES 8
thedogmonster
Me too.
A very cool and finicky system. https://community.netgear.com/t5/Troubleshooting/How-re-associate-my-base-station-with-my-account-I-...
I hope it works for you as well.
thedogmonster
Burnn1
It must be my cool moniker.
Burnn1
This worked great - had to add the base station then resync the cameras - back up and running - thanks much.
burnn1
librag2214
Hello
I delete my camera by mistake and now i am trying to sync it and is not syncing what should i do
Make sure you deleted it from Settings, My Devices. When trying out sync be sure to only press the base sync button brief - don't hold it.
librag2214
Is not showing in settings, the blue light blink slowly for a long long time and rwfuse ro sync
Power cycle the base and open and close the battery door. If that doesn't work, open a case with support using the Contact Support at the bottom here.
