  • 1520 Views
Greatpag
Camera sat for about 1 month with dead batteries. Replaced batteries, now will not sync with base. Hit the Remove Device option and tried to rejoin but still will not work. Any ideas?
Are you sure the batteries are good and properly installed? Do you see a blue flash of the LED when you close the battery door?
Greatpag
Batteries are good and installed correctly. The LED illuminated blue when the battery compartment is closed. When I try to sync with base station the LED flashes blue continuously and never stops until I open the battery lid again.
Sounds like a bad camera. Swap at the store or open a case with support:
