Whats my next step?
By "communication" LED, do you mean the Internet (2nd from left)? That's good.
For the rest, your home WiFi has no bearing since the cameras and base use their own WiFi that you have no control over. You can use a WiFi monitoring app on your phone to see the Arlo WiFi which could be a good idea - if it's not present with other signals, that may indicate a bad base.
Also, never totally discount batteries or range since weak batteries and/or wireless interference on the 2.4GHz band can easily be an issue and not necessarily one that's obvious.
It's possible that a factory reset may straighten things out but check other things out first. You may want to contact Support using the Support link above to see if they can help.
Edit: Oh, yeah, power outages can cause this sort of weirdness, too. Most times the cameras will reconnect but sometimes they don't. The use of a UPS/battery backup for all networking equipment can help a lot. You don't need to get crazy - a $100 750VA unit will work fine for many hours.
I use a battery backup, so that's not an issue. Cams are less than a month old...batteries are fresh and full. Something weird has definitely been going on lately.
Could be a bad base. Use the Support link at the top here and create a trouble ticket. After additional troubleshooting steps, there could be an RMA.
