  • 1 Reply
  • 701 Views
WoodyTBeagle
A few things - whoever designed this forum to require a model number in the title, What a nonsense, hoop to jump through for NO REASON AT ALL.
Second - I have owned this product for like a couple of months.  I had it set up so it worked fine for a while.   It was alerting me only when someone came to the door.
A few days ago - it started alerting me every couple of minutes EVERY TIME SOMEONE drove in front of our place.
I DO NOT CARE ABOUT PEOPLE DRIVING ON THE STREET!!!!   I do not want these alerts.  At all.
The app seems to correctly identify these as vehicles.  WTF can't I screen out all alerts for vehicles.
Why are my settings (I have not changed them) suddenly not working????    This product is quickly becoming more trouble than its worth.
You can.  Go into the smart notifications, select the camera, and disable vehicle notifications.  Perhaps also consider disabling "all other motion".
If your app shows "Library" at the bottom refer to the first link; if it shows "Feed" and "Dashboard" use the second one.
  1. https://kb.arlo.com/000056585/What-are-Arlo-s-advanced-motion-alerts-and-how-do-I-set-them-up
  2. https://kb.arlo.com/000062927/What-are-Arlo-s-advanced-motion-alerts-and-how-do-I-set-them-up-Arlo-S...
You will still get recordings, but you can also filter those when viewing.
  • 1 Reply
  • 702 Views
