have problem with my doorbell that in the past 3 days it recorded like 5 mins each time with no movement at all. I reset it but still not better. Also not record person movement today as well. Anyone know how to fix it? Thanks
Can you make manual recording?
If so, are you seeing motion in it? Or does it look completely still?
Also, are you see any obvious artifacts?
Can you answer the question I posted above?
Can’t do manual record.
Then I think it is likely due to a lapsed subscription. Did the trial subscription just end?
I have the same issue and i have an active sub. My record times are 5min per recording and they are no longer consistent. I can't manual record either. I've removed and resynced.
The only way to get 5 minute recordings is to use the record until motion stops choice instead of a timed recording. Since the camera must decide when motion stops, the recording time may vary from 5 minutes down to ~10 seconds - that's normal. It's all about how the camera can detect any motion.
WHat do you see when trying to manually record?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
