Video Doorbell call no video feed after answering.
When someone ring at the doorbell there is no video feed after answering.
But you can get live feed within the app.
Only sound works when answering.
TxT,
Try reducing the doorbell resolution in your doorbell video settings. Test again, do you still experience the same behavior?
Its not a problem to watch videofeed. But when someone is calling I only here the sound and no picture
TxT,
What model mobile device are you using and who is the service provider?
Is there any difference in behavior when the mobile device is connected to WiFi vs mobile data?
Latest firmware.
It’s the same with wifi and mobile data.
It’s so strage cause when I just wana look on the livefeed it work just fine.. only when someone ring the doorbell its not working
TxT,
Check your iOS settings and make sure all the permissions are enabled for the Arlo mobile app. You might also try reinstalling the app, making sure to allow permissions during app installation.
Reinstall the app.
Gave it permission.
I ser that it is a thread with the same problem I have in the community
I will send you a private message to gather more information on this issue.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
