Anyone having a problem viewing the camera image from the Video Doorbell with an Echo Show 8? When asked to show the front door, my two Echo Show 8 devices consistently time out after about a minute with Alexa stating "the camera is not responding." They do report "activity at the front door" when someone approaches. Curiously, my three Echo Show Gen 2 devices mostly work fine with the Video Doorbell camera with an almost immediate view of the outside. I have submitted a ticket to Arlo support, which has been upgraded to a higher tier for engineering, but the representative told me that despite known concerns with the Video Doorbell and the Echo Show 5, mine was the first complaint regarding the Echo Show 8.
For those experiencing an issue with using your doorbell with Echo Show devices, try reducing your Arlo Video Doorbell resolution.
You can find this setting by logging in to the Arlo mobile app and navigating to Settings > My Devices > select your doorbell > Video Settings > Video Resolution > 1080sq
Reproman,
I will take a look at your open support ticket and request an update.
mndeutschland,
Alexa integration is supported with Arlo Video Doorbell. Are you using an Echo Show 8 as described by the original poster here or a different Alexa device?
I don’t have problem showing my arlo q cameras. Fire TV stick 4K works for all my cameras.
Thanks. That got my Echo Show 8 working with the video doorbell. Shame it won't work with the higher resolution, but at least it's now functional.
Lowering video quality worked for me. But something I did notice that others might see as well.
I had to start a live view of the new resolution before it would start working on either my 1st gen or 5.
New door bell which was installed yesterday. It will show show up live on our Alexa Show 8.
"Waiting for Arlo" for about 5 seconds and then "Front Door is not Responding".
I tried 1080, 720 res and removing and re-adding it to Alexa. It gets the motion alerts right away. It seems like it gives up way too easily.
We have 1GB fiber internet and good coverage.
The app takes ~2 seconds to connect live normally.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
