UK Video doorbell installation
Hi all.
I'm looking at whether the Arlo Video doorbell will be suitable for my home. It's new-build house and therefore has a modern chime-box, fully wired.
I've took the cover off the box and it looks to have sets of power inputs, one labelled "AC 220-240V" and the other "Bell Push" (photo attached) - which one (if any!) of the two should I connect my Arlo power kit to?
Also - If I order from Amazon America, will I receive all the bits I need, or should I hold off until July and order from the UK store (there's quite a big price difference - even with postage and tax taken into account!)
Thanks all.
Jamie_1862,
Arlo Video Doorbells are designed specifically for the regions in which they were purchased. Purchasing a kit from outside your country means the appropriate parts may not be included. When you purchase an Arlo Video Doorbell in Europe, you receive a doorbell transformer in the package. If your current doorbell does not provide 16-24V AC, then you must use the included doorbell transformer. For help installing the transformer, visit How do I use the transformer that came with my Arlo Video Doorbell?.
For more Arlo Video Doorbell information, take a look here:
How do I install my Arlo Video Doorbell?
If you need further help, contact a local electrician or professional to assist you with installing your Arlo Video Doorbell.
Thanks for the response regarding buying out of region - will hold on until the UK unit becomes available.
Still have a question regarding connecting to my door chime.. is anyone able to help? 😊
hi, I have the same doorbell chime, this can be made to work with the arlo bell by utilising the 24v transformer arlo provide to power the doorbell and a 24v AC relay which is switched by the bell and operates the original chime.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
